Clutch Shell Wobbles - is it normal?
Hi everyone,
My clutch started to slip when I went full throttle at about 3700rpm in 5th gear. I adjusted the clutch, changed primary oil - no improvement. I took the friction plates out, they looked ok. I read in the forum, that I should change the spring plate in the clutch pack to 2 steel plates and a friction plate. Not sure if it's a good idea to change all the friction plates while the cover is off..
My biggest question is about the clutch shell movement. I noticed that it wobbles a little. Please see the video. Does it look like I need a new bearing? should i get the whole assembly instead?
It's a 2014 Iron 883 converted to 1200 with a heavy duty clutch spring.
vamgnt (05-05-2020)
vamgnt (05-05-2020)
