Shifter shaft oil seal
If they are both the same size then it should not matter. However if the bore the seal fits into is not the smoothest or has a few nicks or whatever, then go with the rubber encased one. Otherwise again, it don't matter. Just a different style. I find the rubber encased ones are easier to install. Put scotch tape on the shaft splines and a little oil over the tape before you slide the seal over the shaft shaft splines so you don't damage the seal. YD
