Hard shifts into 2nd gear
2016 FLHXS w/ 18k miles
I have noticed sometimes (I'd say about 30%) of the time, when shifting from 1st to 2nd gear it seems to be a somewhat rough transition. What I mean is just a rough shift, almost like feeling some type of vibration in the shift shaft.
Yesterday I actually happened to really get stuck in neutral when going from 1st to 2nd and it really took a few attempts to get back into gear.
I'd like to add I really only notice this when getting on it, not just putting around.
Bike is Stage 1 - pipes, tuner, air cleaner - nothing else modded performance-wise. Running Amsoil all 3 holes, freshly changed a couple of months ago.
Any recommendations?
Check your shift linkage , any play in it , might just need to be re adjusted . If the heim joints have to much play or are too loose , you'll have to replace them , you can replace them with better ones from any parts store , just need the proper sizes . Also , check the front and rear shift levers and make sure they're not stripped or loose . The front shift shaft and spacer should be greased as well . Make sure the rear heal shifter , if your using it , isn't hitting the floorboard as you shift , may need to be readjusted .
If all that checks out , maybe the clutch needs to be adjusted or clutch cable replaced .
Hope it's not serious and you get it fixed , good luck !
Check your shift linkage , any play in it , might just need to be re adjusted . If the heim joints have to much play or are too loose , you'll have to replace them , you can replace them with better ones from any parts store , just need the proper sizes . Also , check the front and rear shift levers and make sure they're not stripped or loose . The front shift shaft and spacer should be greased as well . Make sure the rear heal shifter , if your using it , isn't hitting the floorboard as you shift , may need to be readjusted.
Did an entire clutch fluid flush beginning of this season.
Nope, deleted it. I felt it was always in my way.
One thing I did notice when inspecting everything, the connecting arm that comes up from the transmission is nice and tight to the splines of the shaft - but that actually shaft has some play (I'd say about a 1/4" of an inch) in and out of the transmission. I can wiggle it back and forth with my hands. Is this normal? I can post a video if that's easier....
Too tight hemi joints if you have that set up is worst then too loose. Harleys' have a very slight angle that locks the drive dogs in. It will also pull shift in if linkage is not tight from aftermarket China hemi joints. Also, I assume your oil is not too thick since who knows what substitutes are.
https://streamable.com/u9pqd2
Max, I might have over-exaggerated it's more like a 1/8 inch. Here is a video...is this normal?
The entire shift linkage system is brand new,
