05 roadking nut won't bottom out on clutch basket
I just did a gear set swap in an 05 road King. Had a Bros probationary member attempt to push bearing out of the inner primary and broke it. The original inner primary was part number 60677-01c, I replaced it with 60677-01a. The gear set I swapped with after comparing the length of the splined portion of the main shaft was longer than the original. And what I thought was the cause of the clutch nut not bottoming out and holding the clutch basket tight probably 3/4" of play between inner primary and clutch nut . I since pulled the gear set back out, put the original in nothing wrong with gear set, doing all this cuz of bad main bearing. Get the original gear set in and back together and still can'tget the nut to tighten up on the basket. The only other possibility is the inner primary. Anyone know anything about changes to these inner primarr
Just re-read this. You swapped inner primaries because the original cracked when removing bearing. So inner primary and main bearing in tranny are now what is new. Orginal and a new gear set both have an issue.
https://partsfinder.onlinemicrofiche...davidsonmc/526
60432-1 is what is listed for the primary of 2005 FLHR. I would think FLHs are same, but did not look at other years.
I've had my 01 and 07 off many times. Also replaced them. Don't recall washer. Stuck good, as almost permanent?
F150HD
50
06-20-2023 05:41 PM
bad tappets
07-21-2021 07:15 PM
rakanghoth
04-13-2020 07:57 PM
