Stiff clutch
Stiff clutch
Just bought my wife a 2002 Heritage.
I read here somewhere that pre-2006 they didn't have an easy pull, but I'm no wimp and it seems to be pretty stiff. Only 15,000 miles on the bike but it has sat around for a few years. Do you think it might just need some lube in the cable, replace the cable? Or is it known that the clutch on this year of bikes are harder to pull?
OregonMark (04-30-2024)
The following 2 users liked this post by Ohio HD:
eighteight (05-01-2024),
OregonMark (05-01-2024)
https://www.harley-davidson.com/us/e...8a2f4a4d4d55/y
Interesting, I'll definitely try that on my '98...however it looks like the ramp changes happened in 2000, not 2006 so the OP should already have the newer style on his 2002.
First released in 2000
outer ramp 25605-00 21 Degs
inner ramp 25604-00 21 Degs
released in 2006 part of HD's Reduced Effort Clutch Kit
outer ramp 25605-00A 18 Degs
inner ramp 25604-00A 18 Degs
08xl1200r (04-30-2024)
By the way, your 1998 has 18° ramps that are different parts numbers from the TC parts.
Last used in the 1999's
Outer ramp 25453-87A 18°
Inner ramp 25452-87A 18°
No the 21° ramps are discontinued. Part numbers below. When they went to the 'A' suffix they changed for all Twin Cams. When you look up parts online you only get the superseded part numbers. To get the original part numbers you have to have factory original period correct parts manuals. I have several years, but unfortunately not all of them.
