shifter needs lots of movement to shift
My wifies 86 Sportie 883 just got a new set of forward controls.I have them set up properly (I think). Before that she had mids and you had to poke your foot thru and you'd almost be pointing straight at the ground during upshifting.
Now with the forwards the problem is more evident. Upshifting seems to require Waaayyyy to much movement before it will actually shift. I know i need to do a clutch adjustment but I dont see how this would affect the shifter movement. I'd say its in the area of 2 1/2 to 3" before it will shift.
I have the shifter set so it actually hits the highway peg going into first. So it's as low as it can get. Just seems to be too much play.
I know it's apples and oranges but my new 2008 doesn't have that sort of play.
Any ideas? Need moreinfo?
[IMG]local://upfiles/47452/6BE398DC5F8D440397EFCC37413FA59B.jpg[/IMG]
[IMG]local://upfiles/47452/DAEC8CCE0E104606A93809A432DBFDB1.jpg[/IMG]
RE: shifter needs lots of movement to shift
I have to imagine that any stock heel toe shifter should work? I mean the shift rod is the standard diameter even tho it is the aftermarket shift rod as part of the forward control set up. Anyone ever done this on an aftermarket kit? i think the maker is R/N
