Primary Drain Plug
Primary Drain Plug
After I changed the primary oil a few thousand miles ago, I developed a small leak at the drain plug. I just changed it again and noticed the threads on the plug were a little “sharp” like it might have been cross threaded. I reinstalled with a new o-ring and teflon tape, torqued to 55 inch pounds. Now I get 3 or 4 drops overnight. I would really appreciate any ideas you talented gear heads might have
RE: Primary Drain Plug
Go get a new plug maybe. If you are using teflon tape & new oring you may have stripped the threads in the case. You may want to chase the threads in the case by using a new bolt the same size/thread or a tap dipped in some oil to clean any metal or gunk off of them. I use white loctite on the threads of all my drain plugs because it is a hydraulic locker/sealer. You can get it at autozone.
ORIGINAL: Viejo
...I would really appreciate any ideas you talented gear heads might have...
It's also important to lube the new o-ring as they do have a tendency to twist and tear if installed dry.
Good luck!
BigFatHawg
05-10-2010 06:18 AM
