Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Main Drive Gear O-Ring?
Old 10-27-2008, 08:27 PM
Z's Avatar
Z
Z is offline
Default Main Drive Gear O-Ring?
98 Wide Glide
I'm installing a new main drive gear and I think I'm missing something. Do I need an O-ring or something on the main drive gear, in the location shown? The SM and parts catalog don't show it clearly enough for me to be certain.
Thanks for all the help you've all given me on this project!
Old 10-27-2008, 09:12 PM
Rider57's Avatar
Rider57
Rider57 is offline
I believe the quad seal go there after you install the gear. If that makes sense? On the outside in other words, other side of the bearing.
Old 10-27-2008, 10:04 PM
Z's Avatar
Z
Z is offline
Rider57: Thanks, and I believe you're right about the location of the quad seal.
Here's a scan of the picture in the Service Manual. It looks as though there's an O-ring on the mainshaft which would have to be in place before the mainshaft is installed into the transmission. On my mainshaft, where there appears to be an O-ring in the picture, there is a relief cut into the shaft that looks like it was designed to accept an O-ring. I'm fairly certain that the quad seal goes on after the mainshaft has been installed.
My question is, am I supposed to be installing on O-ring on the mainshaft prior to installing it in the trans?
Old 10-28-2008, 11:31 AM
Rider57's Avatar
Rider57
Rider57 is offline
Try getting a look at a Parts Manual for the year model. It will have a blow up of the components. Thats the only sure way to know. I dont know why there would be a O-ring there as there is the seal on the outside as well as the quad seal. Hate to say "go to the dealer" and ask one of the service techs. If they wont help, try to find a local indy.
Old 10-28-2008, 11:32 AM
Rider57's Avatar
Rider57
Rider57 is offline
Wait a minute. I tore down my 97 RK tranny to replace the same shaft years ago!
No. There was no O-ring there. I think that groove is to keep lube from "walking" and loading up the main bearing.
HDF Tech
09-14-2021 01:23 PM
LQQK_OUT
02-10-2019 02:36 PM
1964duoglide
05-08-2018 04:28 PM
prplglide
14
05-22-2013 10:52 AM
Bohemian
Shovelhead
12-01-2012 11:36 AM
Quick Reply: Main Drive Gear O-Ring?
