Rear sprocket
Rear sprocket
Have 07 RKC with IDS 66 tooth sprocket.
The QUESTION Is?
Does harley Make A 68 tooth sprocket to fit the IDS. How much do you have to change?
What kind of speedo error would there be?
Yes I did do a search. Came up with all kinds of primary drive changes. No final drive changes.
Believe 07 bike needs a little lower gear to start out with under a tour load. Sprocket change the quickest.
Thanks Ace
The QUESTION Is?
Thanks Ace
