Main Drive Shaft Oil Seal - Replacement Cost at Dealer?
#42
I received my package from Cometic yesterday and will be putting everything back together tomorrow.
I have removed the inner primary bearing race and had a local shop press out the old bearing and replace with new bearing from Baker. I have installed the starter jackshaft seal and mainshaft seal in the inner primary.
I will be installing the other seals tonight/tomorrow and buttoning it all back up.
A couple lingering questions. Should I use blue loctite on all fasteners except for the compensating sprocket nut, and the main shaft nut, and use red loctite on these?
What about the bolts for the pulley lockplate and the Starter bolts? red or blue?
Also, when I removed the inner primary, there seemed to be a bead of silicone type material on the mating surface with the crankcase. Although, I only saw a round gasket/o-ring for re-installing...Should I be putting something on here?
Thanks again for all your assistance, you guys are very helpful.
#43
I appreciate all the responses. Lots of good information. I don't know how anyone can own a Harley and not belong to one of these forums. Like OneBlackFly, I don't want to tackle this problem either, but money, or the lack thereof, is a good motivator to try to fix it myself. There seems to be different opinions on whether the leak is damaging the bike (dirt in seal scoring the shaft?). If I knew for sure no harm was happening, I would opt for just topping the tranny off once a month. Wouldn't be more that a quart during our short riding season up here.
This leak will do damage to your drive belt, I have the same leak and I am now pulling my bike apart to replace the belt, which is not very worn, but still broke due to the fluid leaking onto it. My service manual also states that this can make a belt prematurely wear.
#44
I am going on a year now and three changes of all seals as well as a new main drive gear and I still have a leak. This has been the most annoying leak I have ever experienced, oh and by the way during this leak I have redone base gaskets and replaced all the way up to have a rocker box warp and have to be replaced and then the moco gasket failed to have them replaced again and then the transmission started leaking as well. This year has sucked and my primary still has a leak. Now everyone is telling me that my inner mys be warped and of course it is discontinued by HD. with the 3k I have spent on chasing leaks this year I could have bought a sporty and had a bar hopper.
Thanks for letting me git that off my chest.............
#45
#46
My .02, take the $300 you were going to spend at the dealer and buy a Service Manual and a couple of tools special tools (Compensator socket, clutch hub socket, and mainshaft bearing inner race tool). George's Garage is where I have bought several of my tools. Order a bearing kit from Baker for the inner primary and you won't have to reinstall the race. Only other tool other than normal hand tools you'll need is an air compressor and 1/2" impact wrench. You'll "want" the impact wrench for removing the compensator nut and clutch hub nut (you can get by without it but you'll probably do a lot of cursing!) This way, you'll spend around $200 and have the tools for later jobs. Honestly, this isn't a hard fix at all. Good Luck
#47
The spacer I`m referring to is the one that is on the mainshaft, behind the pulley, it`s outer surface is the sealing surface for the big rubber seal that is over the big ball bearing. That is the seal that Paul suspects is leaking.
The seal between the main drive gear and the mainshaft would cause the lube to leak on the side of the pulley nearest the primary cover. That is a seal that I think is often overlooked when chasing a leak.
Hotrodz_n_Harleyz
06-21-2013 09:22 PM
