08 SG - rear drive sprocket loose?
I need some advise. I have my bagger rear wheel in the air, I have adjusted the drive belt as pr book, everything torqued properly.
Once I put the rear wheel on the ground, I decided to see if everything was tight, but when I try to rotate the drive belt sprocket I find it moves ever so slightly back and forth, (following the rotation of the belt). Is this because of the compensating cams in behind it or is this an indication of something wrong?
