Ride-On tire sealant
RE: Ride-On tire sealant
ORIGINAL: SLORider
Since the claim is to be able to seal a 1/8 inch hole in a tube tire I would love to intentionally puncture a tire that is due for replacement and see if it seals up. Unfortunatly for this purpose, my tires have quite a bit of life left in them.
Seriously, keep posting your findings here, if you would please. I'll bet I'm not the only RK Classic owner out there who is interested whether this stuff is as good as it sounds.
Thanks for the update!
[sm=thanx.gif]
Bumped for SLORider 's impressions. I also now remember after re-reading his first post that you do indeed have the tubed tires. I, and many others do too and would like to know what you think, now that it has been in your tires for awhile. How many miles do you have on these tires with the sealant injected into them?
Thanks SLORider for your time!
UPDATE--Ride-0n TUBED Tires
Well no flats so far. Good news for me but not necessararly for the test.
I have become somewhat fanatical about my tires since installing the RIDE-ON. Particularly with regard to air pressure. I was getting some leakdown in tire pressure from ride to ride so I bought a nice kit at Auto-Zone, made by SLIME that had replacement valve stem inserts and valve caps with gaskets. It came with a small gauge and other items and was about 5 bucks. I got a new air gauge for my compressor that locks on and gives me a better fill and read.
My tire are riding great with the Ride-On in them. The tire balance feature seems to work well as the bike is smooth going down the road. Again one of the best recommendations to me was the review on the website by Larry Grodsky, he was one of the most knowledgeable riders ever and seemed to think it worth it.
As I put miles on my bike this spring/summer when it comes time to replace the rear tire, I will, under controlled conditions, "take one for the team" and puncture the rear tire/tube and see how it works. I'll get back to you then.
I am getting a new rear tire this week. The question is how to test the Ride On sealant?
My mechanic says we should have the bike on the lift when we puncture the tire, so if it doesn't work we are set to go to replace the old (and at point, flat) tire. It isn't a real world test and isn't even the way Ride On says you need to seal the puncture which is by pulling the nail/screw then riding for a 2/3 miles to heat and seal the sealant into the hole.
Ideally I'd puncture it at home and ride into the shop but I'm not sure I want to do a test on my Medical Insurance and/or my Towing insurance at the same time. I think I'll have the tires warmed up, get it on the lift, puncture, move the hole to the bottom of the tire, give it some time to seal and see if it will hold air.
Anyone got any other (safe and sane) suggestions.
[sm=goodidea.gif]Sounds like a plan to me, SLO.
Maybe after the puncture, you could pull the nail, start her up (while on the lift), put it in gear and run the rear wheel for a bit. I think the premise of the sealant is that the centrifugal force will spin the sealant into the puncture and seal it as the wheel is spinning.
Let us know what happens. If all goes well, I am putting the stuff into my tires this week.
Thanks again, SLOrider. You are really a "team" player. We appreciate your follow-thru and reporting back to us.
[sm=thanx.gif]
