2011 exhaust info
I just did the Crossover system on my 2011 Fatboy Lo. Thanks to MBLOLYFE's recommendation and sound clips. I have the 1.75 and they are way louder then stock. I love the sound. Only problem I had was that after the install of a full system I needed a fuel management system cause the bike was way to lean even with the stock A/C still on the bike. Problem solved now with a SE Stage 1 A/C and Power Commander V Tuner. Oh ya and BTW thanks Ryan for all your help and super customer service
The crossover is my favorite system! Great pic of the bike and thank you for your service to our country.
Ryan
Ryan
We have discontinued the straight cut series of mufflers. However we do offer the tip compatible muffler with tips as a discounted package. An example part number would be 27511-200-pkg with 3015B tips. The tips with a B in the part number indicate a black finish, the 3015B has a straight cut with a slight taper that is similar to stock mufflers. The 3014B and 3015B are currently the only tips offer with a black finish.
-Ryan
The Blackline uses the 27 series: ’07-’11 Deluxe, Crossbones, and Blackline use the same mufflers. But the Blackline uses the Fatboy head pipes, so Blackline riders cannot use our stock replacement heat shields (27510HS) in tandem with the 27 series slip-ons.
-Ryan
-Ryan
-Ryan
Thankyou so much Ryan for terrific customer support, shall go ahead and purchase the 27513-200 ones. will the screaming eagle heat shields work, or are they of different outer size ?
Ryan,
I have just completed a 124" build for a 2009 FLHX. Curently I have the Klock Werks Double back system. the 1 3/4" header size is the limiting factor. I really like the 'true dual' look and realize that I can achieve the max power from a 2-1 setup. I was wondering what you have in your product line that would be compatible.
Cheiron
Cheiron
Ryan,
Cheiron
Cheiron
Thanks,
Ryan
