CVO Air filters
CVO Air filters
Don't all CVO bikes come with the SE air filter kit everyone is recommending? My 2007 SERK has the open air filter housing, but I believe the element is paper. Besides changing the element to a K and N, what is considered Hi flow or stage 1, if this is not. Does anyone know the part number for the K and N replacement element?
RE: CVO Air filters
The SEUC does not come with the SE AC. I believe all the other CVO's do. I had to replace with a new backing plate and the K & N filter. You can go to the K & N website and they have a great fitting site to let you know what to order.
If you do your A/C and improve your pipes or add slip ons, you will need a SERT to remap your ECM. It will help it run better and cooler if you do this. I would say all of this would achieve a "STAGE 1" kit.
Bagged Out
Screamin Eagle CVO Models
13
07-26-2018 09:05 PM
