Will XM from an 09 SG work in a 12 CVO SG?
Old 07-08-2012, 08:36 AM
tpb857's Avatar
tpb857
tpb857 is offline
Default Will XM from an 09 SG work in a 12 CVO SG?
I'm considering trading my 09 Street Glide on a 12 CVO Street Glide. I don't the the CVO comes with XM. Will the wiring harness and antenna mount from my 09 work in the 12? From what I have read so far, it looks like it might not for some reason. Thanks.
Old 07-08-2012, 10:12 AM
zer0t's Avatar
zer0t
zer0t is offline
I'm surprised that the new CVO bike would have XM. Is not an option or just the particular when you are seeing? I would check to see what head unit that have in both....if it's the same then you should be able to get it done. Have you checked any aftermarket add-on e.g. hog tunes to see if they make a module?
Here's a discussion on this topic.
Look at the third post down...this person says there is a module available and perhaps it's the same part number as the one you have.
http://www.cvoharley.com/smf/index.php?topic=48655.0
Old 07-08-2012, 04:01 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Texas Fat Boy is offline
The radios are the same but they left out a wiring harness that you need plus the wiring harness you had to buy with the XM moduel.
I did find enough info on the CVOHarley forum that my dealer did change mine over from my 2009 Street Glide.
http://www.cvoharley.com/smf/index.p...ic=56934.0;all
Old 07-09-2012, 04:22 AM
tpb857's Avatar
tpb857
tpb857 is offline
I have the HD XM in my 09, and it is the XM module, antenna, small mounting platform for the antenna and a wiring harness. It looks like I have to get some additional wiring. Thanks for the links to the other thread.
Old 07-09-2012, 06:00 PM
Texas Fat Boy
They used a wiring harness out of my 2009 Street Glide that the Street Glide's doesn't need.
Old 07-09-2012, 06:20 PM
Glidedsternfan's Avatar
Glidedsternfan
Glidedsternfan is offline
Exclamation $35,000.00!!!
You're gonna be spending upwards of $35K on this motorcycle!
Tell the dealer you want them to move the XM module from yourold bike to the new one. They'll do it. Trust me, they really want you to buy this CVO especially if you're financing through HD.
Have fun with your new motorcycle!
GSF
Old 07-10-2012, 10:05 AM
Texas Fat Boy
GSF
If it's a dealer that only goes by the book they will not do it. The book says it won't work.
Fits '06-later Touring models (except FLHXSE3) equipped with an Advanced Audio Radio. FLHXSE2 and FLTRXSE models require separate purchase of CVO™ Speaker Expansion Kit P/N 76000275. Requires installation of appropriate Wiring Harness and Antenna Bracket P/N 76456-06 (FLH models) or 76316-06A (FLTR models).
That's why I gave him the info on how to do it.
CVOSGBOB
Milwaukee Eight (M8)
08-20-2017 09:47 AM
remo76
02-26-2017 08:25 PM
remo76
Screamin Eagle CVO Models
02-26-2017 07:36 PM
Cvogangganggang
05-09-2016 08:42 AM
James Everingham
Audio Systems
02-08-2012 11:53 PM
Quick Reply: Will XM from an 09 SG work in a 12 CVO SG?
