Want to put floorboards on my '72 FXR
  #31
Old 08-07-2015, 10:33 AM
V_twins's Avatar
V_twins
V_twins is offline
yep!
ha ha... listened to it the other day...
  #32
Old 08-11-2015, 08:17 AM
AJSHOVEL's Avatar
AJSHOVEL
AJSHOVEL is offline
Received 10,501 Likes on 4,144 Posts
Originally Posted by SIKDLX
I have a 82' shovel and busting my brains in finding a way to run floorboards hahahah that fabkevin in piece is just an adapter and what floorboard set up so I purchase? Mahaloz for your help!!!
As Racepres stated, Heritage Softtail or Fatboy ('86 to '99). If you look at all the parts, they are very similar to the parts of an FL Shovel. The big difference on the shifter side is that there is a bracket for the rear footboard mount that takes the place of the primary tab (which I'm assuming you don't have).
On the brake side, the mounting bracket has the rear footboard mounting as part of it, to take the place of the frame tab (which you may or may not have). This is the only thing that can give you fits with your exhaust since it is permanent and doesn't give you the option of different brackets to clear different exhausts.
Also, keep in mind that the early footboard's mount spacing was 10" and the later Softies mount spacing is 8".
A lot of guys took off their footboard assemblies in favor of aftermarket forward controls on their early FL Softies. Do a search in the Softtail section or the wanted section of sites like the Horse Backsteet Choppers.
  #33
Old 08-12-2015, 08:30 AM
Donzie's Avatar
Donzie
Donzie is offline
Thanks for all the info!!
  #34
Old 08-14-2015, 02:41 AM
V_twins's Avatar
V_twins
V_twins is offline
Built with capacitors and diodes and has a ****-ant sound!
don't want to hijack the thread, but you have a pm
brad75raiders
Classic Harley Parts
08-11-2018 11:30 AM
Hundskrüppel
02-06-2018 01:41 PM
brad75raiders
EVO
09-01-2017 03:27 PM
DBLJ
EVO
10-10-2011 06:28 PM
Nate88hd
EVO
03-17-2011 09:41 PM
Quick Reply: Want to put floorboards on my '72 FXR
