Merry Christmas...how do I get those shock apart
Old 12-25-2016, 01:24 PM
Bill wallace's Avatar
Bill wallace
Bill wallace is offline
Default Merry Christmas...how do I get those shock apart
Sure would like to powder coat this and make it all pretty. How do I get it apart? No retainers on top. Yep, I have a shock tool. It's off a 72 rat bike so it could have come from a different year. Any suggestions?
Old 12-25-2016, 11:23 PM
Hurricane 68's Avatar
Hurricane 68
Hurricane 68 is offline
Default Torch it
Use torch heat up inner sleeve seized to bolt use heat and soak WD 40 or equivalent stuff. Luck
Old 12-26-2016, 08:32 PM
Carlos Frijoles's Avatar
Carlos Frijoles
Carlos Frijoles is offline
Do you have enough clearance to get a 2-jaw puller on there? It might give you enough pull to pop it with a hammer and un-sick it. Heat will work too, but the rubber is going to stink to heaven! Good luck.
Old 12-27-2016, 10:52 AM
Bill wallace
Oops. Bad communicator here. What I meant to say is how do I get the shock apart once it's off the bike. Yes, I stick it in a compression tool and compress it, but is all there is on top is a round plate and no retainers. Anyone know how to get this shock disassembled?
Old 12-28-2016, 11:22 AM
panz4ever's Avatar
panz4ever
panz4ever is offline
Received 3,222 Likes on 1,483 Posts
Need 2 old clutch fiber plates, 2 threaded 1/4 x 20 rods, 4 nuts. Place plate on each end, threaded rods across from each other, nuts one each end of the rod and turn down nuts on one end evenly. You need to compress the absorber spring enough to turn the lower eye stud 90 degrees. It then will come apart.
TwiZted Biker (01-01-2017)
Old 12-28-2016, 07:03 PM
Bill wallace
I knew you'd be the one! Thanks. This thing gonna look sweet. Powder coat the covers black and HD orange on top disc and bottom adjusters...no bottom cover.
Old 01-01-2017, 08:44 PM
Bill wallace
Yep, disassembled the whole rear of the bike and when you turn the shock upside down, it's easy to see how it comes apart. Thanks
Sand850
EVO
13
10-30-2017 06:17 AM
boxfullofbluze
05-28-2013 06:29 PM
brown dawg
11-09-2012 02:53 PM
Dyna346
10-18-2012 10:19 PM
JRK5892
Powdercoat & Paint
10-17-2012 05:43 AM
Quick Reply: Merry Christmas...how do I get those shock apart
