s&s super e gas leak
06-21-2017, 08:13 AM
i have gas leaking out of bellows on on top of the throttle push rod on my s&s super e carb, changed out the diaphragm but still got the same problem, can't think of anywhere else it could be coming from, any ideas?
06-22-2017, 09:56 AM
Check the float level is correct and make sure the needle isn't stuck or gunk is obstructing it from sealing.
06-22-2017, 03:21 PM
Did you just rebuild the carb? Did you install the check ***** in the accelerator pump properly?
fatbuda
EVO
06-23-2017 09:53 AM
elevenbravo78
EVO
13
09-27-2015 03:41 PM
Dr. Fell
Carburetor Related
04-08-2014 05:21 PM
pounder35
12-02-2013 07:50 PM
pounder35
Carburetor Related
11-27-2013 07:19 AM
