81 Low Rider front cylinder running hot
Old 04-28-2018, 04:32 PM
Mike07roadking's Avatar
Mike07roadking
Mike07roadking is offline
I put the old jet back in, it look a bit gray now. I might try a bigger jet. Arrr, go till she blows matey.....
Attached Thumbnails 81 Low Rider front cylinder running hot-f8463566-d56b-4337-9cb0-c283974eaf35.jpeg   81 Low Rider front cylinder running hot-ccd25d3b-18bc-4884-9b69-0fb3fc486992.jpeg
Old 04-28-2018, 04:58 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,818 Likes on 3,320 Posts
I think I would be more concerned with why the rear cylinder is only 190*
Mike07roadking (04-29-2018)
Old 04-28-2018, 06:34 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is online now
Received 47,922 Likes on 17,475 Posts
Originally Posted by Mike07roadking
Now I am running lean again? I went around and reefed on the band clamps holding the carb on and I was able to get another turn or so. Other than that the bike rides great.
Didn't by any chance check the compliance fitting holding that carb did you ? Those are known to crack ans suck air occasionally.
Old 04-28-2018, 08:34 PM
Mike07roadking
I have no clue on that compliance fittings.. If you can elaborate I will check it.
I did check a couple of web sites on that last plug burn, and their picturses say "normal" ?
I'm a bit old school & I thought thought we should be bit tan instead of gray. Any comment?
Old 04-28-2018, 08:39 PM
TwiZted Biker
It's the big rubber spigot the carb plugs into on the intake, correct me if I'm wrong but that looks like a Mikuni or some other non hard mount carb on the bike. Also looks like 2 spacers in between, gaskets or o-rings between would be suspect for a leak too.
Old 04-28-2018, 08:53 PM
81rat's Avatar
81rat
81rat is offline
On my '80 Shovel I add a air leak that was between the manifold and spacers , found it by placing them on glass ( wobbled ) I put sand paper on glass and made flat
Old 04-29-2018, 06:09 AM
98hotrodfatboy
Ok, so it's a kick only bike. Failed to mention that when you you first posted... Your not gonna post hi numbers just kicking it.. Did you have the slide in the carb wide open when testing?
Your not gonna see deposits on the plugs like we used to with today's fuels... When listening to the video sounds to me like it's running pretty good, you just need to find a competent tuner. Is this your first Shovel?
Old 04-29-2018, 07:43 AM
Mike07roadking
There is a bunch of questions from others as well
Yes, running a Mikuni 38MM w/330 Main jet
I can't afford a tunner and it not a race bike, it's trial and error at this point to try to dial it in.
On the spark plugs, they are more gray with some black around the end of the threads. Is that trulley lean?
I'll go around again and reef on the fasteners around the carb some more, but shouldn't it suck in carb cleaner spray if it's leaking? It just pulls up and drips.
Also it does have electric start (alls *****)but it kills the battery and the aftermarket solenoid stick sometimes, so that's why I kick it most of the time. But the compression test was first done with the elec. starter then finished with the kicker after the battery died.
I have owned the bike since new, but it has been off and on the road over the years.
Old 04-29-2018, 08:47 AM
Mike07roadking
I am getting a head ache...
Can someone tell me the difference between a plug that is hot and normal? The champion site appears to shows the same plug in both pics.
this is a hot running plug:
Old 04-29-2018, 08:48 AM
Mike07roadking
This is supposed to be a normal running plug, looks hot to me....
Quick Reply: 81 Low Rider front cylinder running hot
