Are these solid or hydraulic lifters?
Hey Guys,
Thought it’d be a good idea to adjust my lifters before firing up an unknown motor. Do these look like solids or hydraulics? Every bike I’ve owned had solids and they don’t look like solids...so my guess is hydraulic.
They spin (with some effort) at BDC, which is how solids should be adjusted. Don’t know if that’s normal for hydraulics.
Book says to loosen the locknut and screw them all the way down until the lifter is fully compressed and then back it out 1-3/4 turn. Does that sound right?
Received 3,232 Likes
Bill wallace (05-15-2018)
Bill wallace (05-19-2018)
Don't mix the pushrods with other brand lifters is what I meant. If you do take them out just make sure the longer rods if there is any difference in lengths go to the exhaust side with the front being the longest. Aftermarket stuff came in all kinda configurations and lengths, not all mixes & matches.
Bill wallace (05-20-2018)
Hey Guys,
For for the first time I'm doing the lifters on my Shovelhead i believe they are solids not sure..Are these definitely solid lift that I quoted.? Mine do not have springs on the lifters just a solid cup, when I do adjust a zero lash and then 3 full revolutions (like a hydraulic) i have piston to valve contact when turning the motor over by hand with the kicker if I just adjust them to zero lash I have no problems.? The cup is just a solid piece coming off the lifter no springs. The push rods have the adjusters on them. I'll try to get a picture later and post it thanks...
An FYI, some solid conversion kits have a spring, DO NOT confuse this as being a hyd. setup and needing preload like the 3 turns down, it was a gimmick to try and kill the lifter rattle solids have that never works.
98hotrodfatboy (08-24-2018)
to go further on twists explain - the HYD lifter pushrod has a 1/4 inch nipple on the bottom that adjusts and a 3/8 ball on the top of the pushrod
conversion to solid ((( an oem hyd lifter ))) uses a 3/8 ball on the top of the pushrod But some have a 3/8 on the bottom with the adjustment others have a 7/16 ball on the bottom - and that only works with the correct insert to the oem lifter ( don't blend ) ---- and some kits like twist said have a spring ( that does nothing but cause questions ) and it is under the insert you install in the lifter to convert to solid lifters
other solids exist but that is for what they come into play with another job
Bill wallace (08-24-2018)
