My new 66 FLH
Received 4,930 Likes
Nice looking bike, I would have no issues riding her as is, flames are OK, as stated, I have seen way worse. Unfortunately you are a country mile away from stock, gonna coast some serious coin to get her back to AMCA standards if that is the plan. You might consider just riding her around for awhile and think about what you want to do, really is a cool bike already. Just my .02, have fun and good luck.
PS yeh the throttle cable is awful, they make internal throttle kits that will work with a cable, easier way to go if you decide you like the apes. Exile Cycles sells a really good unit.
hellonewman (07-20-2018)
1966 Electra Glide (08-21-2019)
the bike was originally foot shift and the clutch is a mouse trap style
the generator and regulator while it seems to be a cycle electric - good stuff - its not correct
the battery box cover is a re pop at the tab on the lower attachment is slotted it should just be a hole
the bracket holding the starter end cap is incorrect it uses two transmission bolts not one no chrome on any brackets, note - I don't see the starter relay they did something different cant tell from the pictures, but I also don't see its attached bracket on the battery box but it could be - or one can be welded in place
the outer primary is incorrect and the spud on the starter will be different as you need a special one for that cover to work - they only came in FLH style with the floor board tab has a sealed derby the inspection hole has the passenger peg mount for the buddy seat - will add pictures of some of this so you know what to look for
the inner primary oiling system must be an add to and change type - not a feed return system as the oil pump that is incorrect for the year it should be an iron pump does not have the lines for oem set up
as we talked a OEM USA made wire harness in complete form is not available - but a partial is plus wire in the correct colors in running feet is available so it can happen - and the front board and the side board under the coil you can get kits for both all new hardware - lets hope you have an original dash plate need a picture
my guess from a 1000 miles away is both fenders are correct oem - the front with its holes on the right places and the rear has rear side rivets you don't get re pop - right side fuel valve you don't get as well unless its OEM
original handlebar switches are hens teeth and pricy worn out - china ones while they work for a while do not have correct wiring But look the part installed - we have put the correct colors and wires on them its what its become - BUT I see them at swap meets for sale new in OEM boxes / paper bags from Harley as well as handlebars - pocket dent for sure -
you do have the correct oil tank < real good thing
to be continued
to be continued
