82 FXR Cam question 3B996
This bike has a 98" big bore stoker with solid lifters. Fresh rebuild on the motor, but it has been sitting for some time, the best I can tell. I had a local shop verify the 98" crank and perform a leak down check for me last year. The results of the leak down test was 5% on the front and 3% on the rear. I love the bike, but I am having a hard time justifying having it not ridden much. Considering selling it, but I wanted to confirm the cam setup.
Andrews B is small for a 98 inch motor - different equipment you get different results in a leak down - i would not be happy 3 and 5 percent on my equipment but again different in pressure has an effect and gage quality has an effect and what did they do with adding oil or not - lots a parameters in play
on my equipment 3 and 5 would tell me the piston to wall clearance is too tight and or the rings gaps are too small as well or even total seal rings that are a no go for me - we would go looking - but again thats my equipment in my shop not the one you went to
so get it running and ride it then if its not you sell it
Curated Content Editor
FXR Models
07-30-2021 11:44 PM
