diaphragm clutch installation on '78 FLH advice needed
Hi all,
The way it is described means that a 0.010 gap will set the correct pressure across the spring. That is the main info I needed. Thank you very much for the explanations, it all makes sense now.
I have to say that the simplicity of this vs the old set up made me suspicious that maybe I didn't have all the parts but obviously it was designed that way.
Although I have already set the whole thing up I am still waiting for a clutch hub nut seal to be delivered (the bit that went wrong and set this whole thing off) so when I get that I will do the pic/description thing and post here. I have done this before on other forums (for cars) so should be OK.
This weekend hopefully!
Cheers
Paul
Cheers
Paul
I have an instruction sheet for another brand name set up and the adjustment procedures are exactly the same . I'm not having any luck getting a decent copy to come over so PM me and I'll send you a PDF file by email .
TB
Hi All,
Quick update. Have set the clutch according to the instructions you all gave and it works perfectly. It took all of 15 mins to do with just one 14mm spanner and a screwdrvier - could not be simpler!
Thank you very much!
However: I have a new problem which I will put in a new thread... "Oil leak - electronic compensating sprocket??"
Once that is done, I will do a running report and photo montage on how to put the entire primary side on a '78 FLH together.
Cheers
Paul
Cheers
Paul
This is the one I bought and used (make sure it fits yours):
http://cgi.ebay.com/ebaymotors/DIAPH...Q5fAccessories
Gets you all the parts you need.
Use your old clutch basket and clutch pressure plates and steel rings. I'd advise you to buy a new clutch hub nut seal (as you are in there) and remember the clutch hub nut is a LH thread!
Good luck!
Paul
Good luck!
Paul
old evo
04-01-2008 07:32 PM
