1975 Shovelhead
Hey guys I posted several months ago about a 75 shovel I bought. She had about 200 problems to fix on her, Glad to say she is running great now, other than some minor carb adjustments and possible smaller jets. Im periodically toying with carb and checking plugs before I get the jet. Other than that, its time to start cosmetics! 1st thing im doing is getting those damn pipes to mount straiter "the rod they mount to is the wrong one" I fudged it to get her running :)
1975 Shovelhead FLH Miles: 22k Odometer Paid: 4500$ Parts: 1539.93$ Misc: 300$ Total: 6339.93 **Stuff I Fixed/Replaced** NEW CYLINDER HEADS *REPLICA 1966 TO 1977* V-TWIN MODEL 5 GALLON FATBOB GAS TANK 40" SLASH CUT DRAG PIPES ADVANCE UNIT ASSEMBLY S&S SUPER E MASTER REBUILD KIT DUAL STAGE SUPER FILTER FITS 1 CHROME FORK BOOT CAPS OIL TANK TEMP GAUGE DIPSTICK COPPER PLUS RN12YC SPARK PLUG EXHST PIPE/CYLINDR HEAD GASKET ROCKER ADJUSTER KIT FUEL LINE - 1/4'' I.D. X 19'' COMETIC GSKT SET FOR SHOVELHEAD DYNA S DUAL FIRE IGNITION KIT S&S Oil Pump http://s16.postimg.org/6h11jnoat/DSCF0131.jpg http://s17.postimg.org/e7blap72n/DSCF0133.jpg |
Great looking shovel. Timeless look of a Harley. Gotta love it. Good work keeping one more troublehead alive.
Man, that is SWEET!!! I've got a '79 FXE that's a hot mess compared to yours. Congrats! :icon_eddie:
get rid of those champion plugs -- i mean they work but try a set of autolite XS-65 gap them to .040 IF you have an electronic iggy --
those pipes need some type of back pressure or your gonna suffer on the low end -- a simple washer welded to a bolt and put 1" in the pipe will give it back pressure -- i made my exhaust --- inside that cone is a SS funnel for back pressurehttp://i1264.photobucket.com/albums/...0OIE/EXPIX.jpg |
LOOK INSIDE THE FRONT PIPE -- SEE THE WASHER?? http://i1264.photobucket.com/albums/...ty_profile.jpg
Speaking of pipes, what's with that front pipe? Does it have a bad bend?
The pipes aren't bad , its the rod that the pipes bolt to down low. I am going to cut it down to square the pipes up more when I tack some washers in the pipes. I slam banged them on, it was the end of the build and I wanted to ride her :P
Thanks for the input :) |
heres the instruction on that washer in the pipe --- http://www.nightrider.com/biketech/exhaust.htm ---
© 2024 MH Sub I, LLC dba Internet Brands
