Carb problem?
Old 04-30-2014, 07:38 PM
Jay09Cee's Avatar
Jay09Cee
Jay09Cee is offline
6th Gear
Default Carb problem?
So I bought a 75 FLH from my dad's longtime friend. He owned the bike right at 20 years but decided to move on to something newer. Its been sitting for quite a few years. I cleaned it up replaced the starter, voltage regulator, and battery and have been riding. At first it seemed rich, kinda chugging and possibly flooding out at take off. When I was sitting at stop lights I could smell gas from the tail pipes. So I adjusted the carb, but not by much and then it seemed too lean popping out the carb on take off. In both situations, it has died on me taking off, but once I get took off its fine. I also notice it seems to surge a little when I am cruising. Now, with all that said let me give a little info. Its bored .40 over, stroker flywheel, and has an Andrews AB Grind cam. And has a Zenith Bendix carb. Someone suggested the carb may need jetted and someone else said I should buy a Super E. Just looking for a little education and possibly a point in the right direction. Any help will be appreciated.
Old 04-30-2014, 07:49 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,553 Likes on 2,882 Posts
post the stroker flywheels numbers can be seen in the timing plug window as you turn the motor around
the carb might be rich because it is too small and it needs to be that way because of the motor size
csd4682
Exhaust System Topics
08-18-2019 04:08 PM
06hds
10-25-2012 03:19 PM
JAMES2
Shovelhead
09-17-2011 07:30 PM
Bruno2
03-02-2009 08:29 AM
Beeracuda
13
12-27-2005 03:16 PM
Quick Reply: Carb problem?
