New member will have loads of evo questions.
few pics of my new old evo
92 Electra glide Andrews ev27 cam , pipes unknown bit not stock. Needs oil pump rebuild, fork seals and brakes suck. So I'll be upgrading them. It's my 3rd harley all evo models. First touring model.
Clean and tidy
Standard wet sumping I need to reseat the ball and check the spring and also the cam breather gear.
Clean and tidy
I thought it was going to be a simple lack of use wet sumping issue, start the bike and with the vent re routed to below instead of the air cleaner its almost like a constant slow pumping of oil out the vent. Rode the bike 100 miles and it seems like the ball isn't seating and the return line is just slowly feeding back a constant smalll flow. Good oil pressure. Which I'm sure will improve once I work out what oil is even in there. Cheers.
