No spark at the plugs
Received 4,366 Likes
Looking at my 99 wiring diagram, the crank sensor has two wires, red and black. Both terminate at the ECM. Gray plug. Pins 5&6. There is a connector in between. It's shared with the cam sensor and can be found under the frame near the front of the engine.
Thw cam sensor is three wires: red/white, black/white, & green/white.
Don't forget to check the banl angle sensor, behind the battery on the rear down tubes. Three wires, light-green/gray, black, & gray.
