Battery died now getting following codes after jump
Old 10-21-2017, 07:50 PM
bond813@gmail.com's Avatar
bond813@gmail.com
bond813@gmail.com is offline
Stage III
Default Battery died now getting following codes after jump
Hey guys,
I have a 2017 Iron 883. I accidentally left the bike on today and drained the battery. After calling insurance to come out and give me a jump now i have a check engine light on with the following codes:
U0140
U0156
B2271
I rode the bike for a bit to charge the battery with no issues but trying to figure out if these codes could have kuat been because the battery died or if something else is wrong.
Thank you,
David
Old 10-21-2017, 08:43 PM
Frostbite's Avatar
Frostbite
Frostbite is offline
Received 3,422 Likes on 1,546 Posts
Old 10-21-2017, 09:12 PM
bond813@gmail.com
Stage III
Sorry should have put in that I have looked up the codes already.
U0140 Lost comm W/BCM
U0156 Lost comm w/SPEEDO
B2271 BCM voltage low
Even though i am showing these codes I have no issues when riding Speedometer works fine and everything starts perfectly. Just trying to figure out what might be causing the issues.
Old 10-22-2017, 08:38 AM
FMB42's Avatar
FMB42
FMB42 is offline
Jump starting a motorcycle is never a good idea (especially when using a car/truck sized batt/charging system). Some people get away with it, but others end up with problems that are far worse than a dead battery. Note: those codes may not have anything to do with the jump itself, but rather the fact that the battery was drained. Meanwhile, you might try 'clearing' those codes by disconnecting the battery for ~ 5 minutes. That said, I recommend that you buy a service manual and a 2 amp 12v battery charger.
Old 10-22-2017, 11:41 AM
bad tappets's Avatar
bad tappets
bad tappets is offline
Probably due to the dead battery. Fully charge your battery (with correct charger), then clear codes, and ride. See if the codes come back.
Old 10-22-2017, 01:31 PM
cHarley's Avatar
cHarley
cHarley is offline
Did you clear the codes and they came back, or did you not clear them?
You clear the code while it is displayed by pushing in
and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Then cycle to the next code and repeat.
M Oclaf (09-25-2023)
Old 10-24-2017, 07:05 AM
bond813@gmail.com
Stage III
Update:
cleared the codes and have rode a couple of time since and check engine light has not came back since. So, im assuming it was just from the batery dieing.
Thanks everyone.
Old 09-25-2023, 05:23 PM
vladsmom's Avatar
vladsmom
vladsmom is offline
Default Getting code U0156 after battery died
I've got an 18 Roadking. I tried clearing the code U0156, but it won't clear. AAA used a small handheld portable jump starter to start bike. Any suggestions? Never had any trouble with bike until this. Thanks for any suggestions!
Old 09-25-2023, 06:39 PM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,645 Likes on 1,135 Posts
Disconnect battery, wait a few minutes (?) and reconnect. Reset whatever needs to be reset, then check for codes. The code says a miscommunication, so clearing out all the boogers and reconnecting the battery is probably a good idea.
John
Old 09-25-2023, 08:26 PM
Rounders's Avatar
Rounders
Rounders is offline
Received 1,852 Likes on 1,462 Posts
Old wives tales that it hurts to jump start a 12v vehicle from another 12volt vehicle
Quick Reply: Battery died now getting following codes after jump
