S&S 113 oil cooler ?
Old 01-18-2018, 12:27 PM
brad75raiders's Avatar
brad75raiders
brad75raiders is offline
Default S&S 113 oil cooler ?
Does the older s&s 113 run hot? I have a motor built in 1999 by horsepower exp and Hannans heads in Hayward. I was told recently by a fellow FXR rider that his FXR runs HOT. and that i should run a oil cooler. Upon Further inspection he has a 113 twin cam in his bike. My question is for those that have or had the 113, Anyone had any problems. The builders didnt bother to run an oil cooler should I?
Old 01-18-2018, 12:47 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
I would put some miles on it and see if it runs hot. Timing or jetting could affect how hot the engine runs. If you really need one, an oil cooler is easy to add later.
aces&8s (01-20-2018)
Old 01-18-2018, 12:57 PM
brad75raiders
I have a 4 row cooler with thermistat i used on my 127 bagger. but that system had a oil filter adapter that i will not be able to use on the fxr. my oil filter is under the trans case.
Old 01-18-2018, 01:12 PM
brad75raiders
Here is a pick
Old 01-18-2018, 01:16 PM
brad75raiders
Can I use that adapter on the older style oil filter mount??
Old 01-18-2018, 01:29 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,245 Likes on 5,408 Posts
Don't need it...just plumb it into the return line to the tank
Old 01-18-2018, 01:38 PM
brad75raiders
This is my oil pump were should I plumbing the other side of the oil cooler? Or just follow the return line from the oil filter?
Old 01-18-2018, 01:54 PM
brad75raiders
Think I answered my own question.... Wierd how that happens.
Old 01-18-2018, 03:33 PM
grbrown's Avatar
grbrown
grbrown is offline
I suspect the engine will be fine, it's the rider who gets hot! We can bake while sitting on these things in the wrong weather or riding gear. An alternative to an oil cooler is one of the twin cooling fan set-ups, which blow air over each head - Love Jugs, or something similar.
Old 01-18-2018, 04:00 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
Hopefully Jasper86 can show a pic of his setup. His is inline and looks okay.
Quick Reply: S&S 113 oil cooler ?
