2018 Heritage 114 - Stag II - Dyno run
Old 01-19-2018, 11:23 AM
Pothole914's Avatar
Pothole914
Pothole914 is offline
Received 3,682 Likes on 1,469 Posts
Default 2018 Heritage 114 - Stag II - Dyno run
Thought ya;ll might like to see the Dyno run after my Stag II upgrade.
The following 2 users liked this post by Pothole914:
smellsbad2 (01-21-2018), Thingfish (01-19-2018)
Old 01-19-2018, 01:29 PM
Thingfish's Avatar
Thingfish
Thingfish is offline
Vey nice!
Old 01-19-2018, 09:07 PM
kenny55's Avatar
kenny55
kenny55 is offline
if i'm not mistaken those numbers look pretty good. What would be any disadvantage to changing out the cams? I've already completed stage 1 but now stage 2 has my interest.
Old 01-20-2018, 12:16 PM
Pothole914's Avatar
Pothole914
The only disadvantage I have found is a sore right wrist. LOL
Old 01-20-2018, 02:32 PM
FatBob2018's Avatar
FatBob2018
FatBob2018 is offline
Received 2,229 Likes on 1,268 Posts
Disadvantages:
1) Sore right wrist
2) lighter wallet (about $900-$1000 for the cam & labor)
3) lower MPG (see #1 above)
Stage II on a 114 M8 is the most bang for the buck of any Harley upgrade. If you've already got Stage I done, Stage II is so close... and so fun...
Old 01-21-2018, 03:13 PM
Another Old Timer's Avatar
Another Old Timer
Another Old Timer is offline
Just had the first ride on my '18 Heritage 114 after the initial 60 mile ride home 7 or 8 days ago due to this bad weather. Bike runs great power is good. Nice and smooth at 70 to 100 MPH, gets to 100 in the blink of an eye...
Question. on my way home, hit it hard in the first three gears and the rev limiter hits at around 5,600 R's. I thought the SE Reflash upped the rev limit to something around 6K R's............Does anyone know for sure?? Pulls like a rocket to the limiter.
Old 01-21-2018, 03:33 PM
kenny55's Avatar
kenny55
kenny55 is offline
Per Screamin Eagle Pro Tuner:
Stage 1, Stage 2 Torque, and Stage 2 Power should all be 6400 rpm
When and who reprogrammed your ECM ?
Old 01-21-2018, 03:40 PM
Another Old Timer
Heck, the dealer did it when the Torque cam was installed.
I thought that it should be higher than 5600 or so.
I'll be calling them tomorrow.
Old 01-21-2018, 03:43 PM
Pothole914's Avatar
Pothole914
It should be 6400 like kenny55 said.
That is what mine is set at.
Old 01-21-2018, 03:45 PM
kenny55's Avatar
kenny55
kenny55 is offline
There is a way to set it manually... the default that comes up though is 6400rpm. Maybe they dial it back. Did they give you the pro tuner module? I assume you were charged for one so you own it and should have it. If you get a cable its pretty easy to plug it in and view/modify the settings yourself with a computer. The software is a free download.
Quick Reply: 2018 Heritage 114 - Stag II - Dyno run
