? Between KW 2+2 narrow and wide bars
Old 02-18-2018, 03:47 PM
PRrdglide's Avatar
PRrdglide
PRrdglide is offline
Default ? Between KW 2+2 narrow and wide bars
I have a 13 triglide looking to see if anyone has used both of these bars and which one you like better. Also when using these bars did they change the mirrors so your shoulder and arms are not in the mirrors. I'm looking to have close to the same riding position as I have on my 03 Heritage Softail. My hands don't fall asleep and have a clear view in the mirrors on the Softail. Thanks
Old 02-19-2018, 06:39 AM
bronxbill's Avatar
bronxbill
bronxbill is offline
I have not used the narrow sweepers but I like the extra 3" width tip to tip on the wide sweepers; gives more leverage in turns. The bars are 2 inches taller, so they should move your mirrors out of your view
Old 02-19-2018, 07:47 PM
Casper's Avatar
Casper
Casper is offline
I’ve lost the part number for the HD wire extensions, can someone post it.
I did a search and didn’t find it
Old 02-20-2018, 06:30 AM
bronxbill's Avatar
bronxbill
If my records are correct, it is 69200034
Casper (03-03-2018)
Old 02-20-2018, 08:53 AM
HogglyWoggly's Avatar
HogglyWoggly
HogglyWoggly is offline
Yup; that's it. Just ordered one.
Switch Wire Extension Kit-69200034 69200034 1
$25.00 $25.00
Casper (03-03-2018)
Old 02-20-2018, 08:32 PM
coronetracer65's Avatar
coronetracer65
coronetracer65 is offline
$25.00 $25.00
Is this for the throttle wiring inside the bars ?
Old 02-21-2018, 02:37 PM
HogglyWoggly
No. Those are the wire extensions for the left and right handlebar wiring. Plug and play.
In my application the twist grip sensor wiring was plenty long enough.
Old 02-21-2018, 03:09 PM
HogglyWoggly
Ruh-roh....my bad.
I just now re-read the original post and saw the OP's trike was a '13. Ignore the info on the wiring extensions as that is for 14 up.
Sorry but I do not have a part number for the TBW extension on the '13.
Hoggly.
Old 02-21-2018, 06:22 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Oogie Wa Wa is offline
I've got the narrow ones and like them; I don't mind the extra effort, these fit me nice. I had a set of KlockWerks Ergo Backs on for a while, hated them.
Old 02-21-2018, 08:20 PM
PRrdglide's Avatar
PRrdglide
Did you replace the bushing also ?
Quick Reply: ? Between KW 2+2 narrow and wide bars
