Sponsored by: Jekill and Hyde
Exhaust modification
Old 05-20-2018, 10:14 AM
Ironworker69's Avatar
Ironworker69
Ironworker69 is offline
Received 1,999 Likes on 1,252 Posts
Default Exhaust modification
I知 looking to quite by bike down some and add some low end torque, I have a Bassani 2 into 1, I知 thinking of adding a disc to the bar in the back, the bar is attached to the baffle and used to install or remove it. I am wondering if it would A: Quite the bike. B Add low end torque. C: Hamper performance and D: Nothing at all.
Old 05-22-2018, 06:26 AM
Big Block 17's Avatar
Big Block 17
Big Block 17 is offline
Putting that disc in there will do nothing for you. It may even create other noises that will bother you more. Look to see if Bassani offers a quiet baffle for that pipe.
Old 05-22-2018, 12:13 PM
nevil's Avatar
nevil
nevil is offline
That disk is way too small. I put in a set of DK Customs TTI's and they take up almost the entire inside diameter of the pipe. It's recommended to remove the old baffle when you do this. BTW, they work great! Deeper sound and very good low range power.
Old 05-22-2018, 12:17 PM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
It is all a compromise-
One thing will make the low end better and the top not so much.
Without a dyno and some research http://www.nightrider.com/biketech/exhaust.htm
you are just guessing.
Old 05-24-2018, 03:44 PM
marcodarq's Avatar
marcodarq
marcodarq is online now
i might help and it might not, the best way to tell for sure would be to take it to the dyno, run it the way it is, then install it and run it again and compare the results, and road test it to confirm. as a tuner i do mods like this all the time, sometimes it helps A LOT, and sometimes not, and the i have had it make wierd noises too. whether or not it helps depends a lot on your build also, so that's my 2 cents.
m
Ironworker69
EVO
05-21-2018 07:02 AM
98hotrodfatboy
EVO
14
03-12-2017 06:49 PM
steelpony16
11-03-2016 10:20 AM
RC07ultra
08-16-2016 11:45 PM
Firedawg24
01-29-2010 05:26 PM
Quick Reply: Exhaust modification
