Rich/Lean Symptoms, please explain
Old 05-29-2018, 05:00 AM
Fblo1690's Avatar
Fblo1690
Fblo1690 is offline
Default Rich/Lean Symptoms, please explain
In the process of tuning my carb. I know that popping through carb is a sign of lean as well through the exhaust. My bike isn’t popping at all, revs fine, just a tiny flat spot at about 1/3 throttle. It goes flat for a second then eventually catches up and continues to rev. I dont know if that’s a sign of bein lean or rich? Bike seems to run a little hot. But maybe not? Oil temp doesn’t go over 200 when riding so might be ok.
I tried the factory settings and at idle I could smell gas out the exhaust. And some gurgling around 40 mph.
Can someone explain what signs of richness or leanness are in different throttle ranges? Thanks ahead of time.
1997 Fatboy
Starting with “Joe Minton Setup”
17.5 Pilot
160 Main
98 needle middle clip
A/S 1.25
Old 05-29-2018, 05:30 AM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
Do it the EZ way-
Amazon Amazon
Old 05-29-2018, 05:56 AM
Fblo1690's Avatar
Fblo1690
Fblo1690 is offline
Originally Posted by Kingglide549
i’m trying to do this by the seat of the pants for the experience.
Thanks
tar_snake (06-16-2018)
Old 05-29-2018, 06:00 AM
Kingglide549
Good luck--
With today's gas which reads anomalies, and most people do not have a clue how to do a plug check.....
But go ahead -
Dont let better tools and science get in your way and make it EZ
Old 05-29-2018, 06:03 AM
Fblo1690's Avatar
Fblo1690
Fblo1690 is offline
Good luck--
But go ahead -
Thanks again.
The following 2 users liked this post by Fblo1690:
Kingglide549 (05-29-2018), tar_snake (06-16-2018)
Old 05-29-2018, 06:26 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,816 Likes on 3,318 Posts
Good luck--
But go ahead -
Don't let better tools and science get in your way and make it EZ
That is so true.... The fuels just don't have the deposits or indicators that they use to (lead for one) and because of that i'd say 90% of Harley owners have no idea what to really look for. Like for example the timing mark on the plug. I'll bet most don't even know that and to tune an engine with the timing off just ain't gonna workkkkk....
I'm trying to help a guy that insists he's running lean. He's using a Wego III so I get him to post charts (run files) so I can download them into my program to see what truly is going on and guess what? He's rich every where except in the high end... Most people should just go to a tuner or do better research. I know this forum is all about helping but!!!!
Old 05-29-2018, 08:57 AM
Kingglide549
I have been wrenching and engineering for years.
The wideband trick is the best tool we could add to our inventory and should be on every
modded Harley.
It should be bolted right to the handlebars and as time goes those that smarten up will do it.
The tide will eventually turn.
I feel like the preacher, "telling people to "save their engines from destruction, Save it now, Save all kinds of time and money by buying a simple gadget
that will tell you RIGHT NOW WTH is going on, and all the internet experts-
can go do something else. LOL
Like you said, and other knowledgeable people too-reading a plug is dam near imposable-plus they have no clue when to pull it.
.Plus, on the side of the road can be pretty dangerous.
Old 05-29-2018, 09:49 AM
Fblo1690's Avatar
Fblo1690
Fblo1690 is offline
Ok. So if I installed this device, rear header? How far down? Also I’m not a fan of leaving it on. Unless I mount it somewhere inconspicuous. Otherwise I’ll become obesessive and I won’t really like the look.
Old 05-29-2018, 10:00 AM
98hotrodfatboy
Front pipe no more than 6"from exhaust port
Old 05-29-2018, 10:01 AM
Kingglide549
Two things -once you mount it you will love it.
There are several styles to choose or buy- with one gauge and a switch read front or rear
Or two gauges ETC
Most- Buy one -Install as per direction about 9 inches dwn on front pipe as it runs leaner.
If you mount the bung on the inside (toward the center of bike) no one can see it anyways
The gauge -put it where thou wants.
You will kick your own **** for not doing it sooner once you start to use it.
Why pay the cost of the dyno room when you can have the very same best information at your fingertips?
Quick Reply: Rich/Lean Symptoms, please explain
