pro action vs super shox vs ?
Old 06-16-2018, 04:46 PM
F350's Avatar
F350
F350 is offline
Default pro action vs super shox vs ?
i am looking too upgrade my rear shocks.i know alot here like the pa`s.have kinda settled on the pa`s but in searching found the super shox.looking for any insight and info for these 2 or another option.good,bad,or otherwise.i do NOT want this to turn into the pa vs ohlins **** show thats been lately.thanks for any info.2016 rgs
Old 06-16-2018, 06:10 PM
dave the welder's Avatar
dave the welder
dave the welder is offline
These threads are almost as much fun as an "oil thread". Pro Action seems to be popular, I just can't spend the 800 bones at the moment.
Old 06-16-2018, 07:20 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Cosmic Razorback is online now
Received 16,758 Likes on 6,896 Posts
A thousand threads on shocks now. As for this forum Ohlins, Legion, Progessive and Pro-Action seem to be the most popular. There are a couple of brands that DK sells also that I cannot remember.
As for the super shox I had never heard of them before you mentioned them on a different thread.
I am sure they are better than stock for sure. About anything is. Good luck with your research.
Old 06-16-2018, 07:55 PM
gosserwb's Avatar
gosserwb
gosserwb is offline
I'm running the super shox. nice set up had then for all of last yr. love them.
Old 06-16-2018, 09:04 PM
binford6100's Avatar
binford6100
binford6100 is offline
Amen to that!
I have the Pro-Action shocks and am very happy with them. One of the guys I ride with has the Super Shox on his 2008 Ultra Classic and has high praise for them as well.
Old 06-16-2018, 09:10 PM
cobaltt's Avatar
cobaltt
cobaltt is offline
I don't know if you will be able to tell the difference in ride quality from PA to super shox. But if you need to adjust the pre-load often, you just can't beat the super shox. no tools required.
Old 06-16-2018, 09:23 PM
hattitude's Avatar
hattitude
hattitude is online now
Received 7,412 Likes on 4,016 Posts
I recently sold my '12 Limited, but I had SuperShox on it for 2 years. They were a good shock, much better than OEM air shocks, and as mentioned above... very easy to adjust the preload from one to two riders, no tools needed.
I have to admit however, they never really made me feel like I had one of the best shocks I could get. I was always still looking and reading about other shocks. I never felt like I found the sweet spot dialing them in. Again, they were a very good shock, just not awesome... I was expecting more.
I have a '16 bagger that I'm about to upgrade the suspension on, but I will be getting something other than the Supershox this time...
Old 06-17-2018, 05:47 AM
santajim's Avatar
santajim
santajim is offline
I have had the Pro Action on my '14 Limited for a year now and won't run anything else. I have had air system because I am short legged and will give up the flatfootedness for the ride any day.
Old 06-17-2018, 07:00 AM
mcouture's Avatar
mcouture
mcouture is offline
I've had Harley's stock air, Harley's premium, JRI and now Pro Action.
The Pro Action's dampening and rebound I find is superior to all the above options. Adjustability on the Pro Actions is real simple too.
Old 06-17-2018, 07:23 AM
lyork's Avatar
lyork
lyork is offline
Pro Actions are super easy to adjust multiple turns as the collar rotates so freely after you unclamp them with an Allen wrench. I can rotate the collar 5 turns as fast as my hand can twist it pretty much.
The ride versus the Ohlins is quite a but better as well. The dampening and spring rate make for a much, much more comfortable ride. However I can’t commemt on pushing it hard into corners, as I haven’t done that with the Pro Actions. The Ohlins were definitely a good shock there, I just haven’t been down a road like that wth the Pro Actions yet
Those Super Shox look like they have a lot of great features. The tool less adjustment is pretty nice. Are they actually a “seperated shock” ? I might have to get a pair and try them out if that’s indeed case
Quick Reply: pro action vs super shox vs ?
