My 2009 Road King Came with Super Tuner Pro, can I use something else?
Old 06-23-2018, 08:25 PM
The Toecutter's Avatar
The Toecutter
The Toecutter is offline
Default My 2009 Road King Came with Super Tuner Pro, can I use something else?
Bought a use 2009 Road King. The previous owner had a stage one kit installed and rineharts exhaust put on and also gave me SE super tuner pro that is paired to the bike. Is there another tuner that I would be able to use other than the SE so I am not locked to going to the dealer anytime I want to change something. Or am i locked to the SE tuner.
Thanks in advance.
T
Old 06-24-2018, 07:07 AM
nhrider1's Avatar
nhrider1
nhrider1 is offline
Thanks in advance.
T
Yes, you can use another tuner. I know the Powervision will work and most likely the TTS. U should be able to use any tuner you choose.
Most tuners are locked to the ecm so they can't be used on multiple bikes, but the ecm can be used with different tuners.
Old 06-24-2018, 08:07 AM
The Toecutter
So if I wanted to install a fuel management system what would be a good one to use? Fuel pro three, power commander,?
Old 06-24-2018, 08:16 AM
Ed Ramberger's Avatar
Ed Ramberger
Ed Ramberger is offline
You have a good one already
Old 06-24-2018, 08:40 AM
jbarr1's Avatar
jbarr1
jbarr1 is offline
You’re not locked to the dealer at all. Like Ed stated, you have a good tuner— no need to change. Software is available online for free download. Add cables and you have everything you need.
Old 06-24-2018, 01:40 PM
shanneba's Avatar
shanneba
shanneba is offline
Pro Super Tuner Software download-
http://prosupertuner.harley-davidson...uperTuner.aspx
A good training series is available at the top right side of the link.
Cables- either a 4 pin or 6 pin cable to match the connector on your bike:
4 pin - https://www.harley-davidson.com/stor...uner-cable-kit
6 pin - https://www.harley-davidson.com/stor...18-41000018--1
Check the fitment tab on the links to confirm the correct cable kit for your bike. I believe it is the 4 pin cable.
Old 06-24-2018, 04:59 PM
Ed Ramberger
2009 is 4 pin.
The Toecutter
06-24-2018 09:40 AM
mhud
02-18-2013 11:29 AM
charloo
01-04-2013 02:32 PM
kdubcr250
08-15-2009 06:01 PM
oldtimer59
12-07-2008 09:15 AM
Quick Reply: My 2009 Road King Came with Super Tuner Pro, can I use something else?
