Front Motor mount Collapse
Old 08-15-2018, 09:44 AM
Huggerbugger's Avatar
Huggerbugger
Huggerbugger is offline
Default Front Motor mount Collapse
Bought a new front isolator for the FatBab and 3 months later it has completely collapsed. DO NOT buy Harley OEM isolators. Took my old isolator and cut the crown off before re-installing and it is collapsing too. My research yields that the Predator and Sputhe aren't much better and certainly not worth $400.
Old 08-15-2018, 09:53 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
Your research would be wrong... jus' sayin'...
Remember, acceleration and braking forces try to push and pull the engine/primary/transmission/rear fork and wheel assembly in the frame through the mounts and engine torque tries to pitch it up and down at the front. The rear shocks exert a constant rearward pull on the engine mounts due to their angle. The HD isolators are poorly engineered but if it did fail this quickly I'd question your vehicle/engine alignment...
crusader1xxx (08-15-2018)
Old 08-15-2018, 09:56 AM
iaminsider's Avatar
iaminsider
iaminsider is offline
I will directly refute the statement against predator. For 1, it is not 400 bux. With today's exchange rate, it is 236 and change delivered to your door. I absolutely love the predator mount. It was night and day difference in stability and vibration reduction on my 2011 Street Bob. I went through 2 OEM mounts, second one collapsed almost immediately after install. Predator is a GREAT improvement.
The following 2 users liked this post by iaminsider:
crusader1xxx (08-15-2018), Daedalus (08-15-2018)
Old 08-15-2018, 10:02 AM
tcazes's Avatar
tcazes
tcazes is offline
idk where you have been researching my friend but you sure have found some wrong information. predator is the best thing i have done for my engine.
Old 08-15-2018, 10:05 AM
Huggerbugger
Engine alignment is fine.
Old 08-15-2018, 10:25 AM
Huggerbugger
Just looked Predator up. About $300 with shipping. CCE has a different style front motor mount at $400.
Old 08-15-2018, 10:35 AM
iaminsider's Avatar
iaminsider
Order the predator direct from the UK, it is 236 and change. I just looked it up for you.
https://www.predatorvcs.com/harley_d...t_engine_mount
Old 08-15-2018, 11:28 AM
fxrnutt's Avatar
fxrnutt
fxrnutt is offline
Sputhe is not an engine mount.....just a stabilizing system...and...keep the oil off your front mount at changes and it will last much much longer
Old 08-15-2018, 11:33 AM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
If your engine is not vertical compared to the frame (Jigged off front wheel)
You are going to get transition.
If your wheel is not centered in swing arm you will get that, plus belt wear, plus transition.
If your swing arm is not centered, you have a shet load of problems ...
and most any of these rubber swing arms with over 5 years on them, sitting or not, are just plain shot.
Old 08-15-2018, 11:45 AM
Huggerbugger
I have noticed that, when idling, the rear fender and tire are shaking from side to side. There's only one bearing and no rubber bushings, though.
Quick Reply: Front Motor mount Collapse
