Crazy Stage 1 Question
2018 - Ultra Limited with Tab Performance slip-ons
I see a significant reduction in MPGs at about 80mph and above. I understand the process of a Stage 1 (air intake and tuner) - greater airflow which then requires a tune - my assumption is more fuel to match the increased air flow.
My question is there a chance I will see better MPGs at higher 80mph and above due to efficiencies created by the increased power or maybe just a better tune?
I understand there are better options, but I will only consider the Heavy Breather and Street Tuner - although I might add some XIEDs
Thanks.
Mike
Thanks.
Mike
Better gas mileage with the stage 1, it makes sense. I thought the same thing, but my 2017 FLHR has about the same MPG`s, the bike runs so much better, so i give it more of the gas. If i ride the bike slow and easy MPG`s go up. this being said, there are other things that effect MPG`s, like tire pressure, the bikes tune SA (spark, timing, map ect)
