Tour Pak
What you'll likely have trouble finding is a rack to mount the Tour Pak to.
I got my Tour Pak used from I believe a 1996 Heritage.
The rack that came with the Tour Pak wasn't a mount but rather just a rack.
The Tour Pak was just simply bolted to the rack.
The rack fit my 09 Heritage and I'm used it that way until I came across a good price on an actual Tour Pak mount.
I'm not sure if a "newer" Tour Pak mount will fit a 94 Heritage.
You might have to find a rack for the 94 then just attached the Tour Pak to it.
Here's a picture of the rack you'll likely need.
Just have someone sit as the passenger and position the tour pak on the rack.
Then carefully drill 2 pilot holes through the Tour Pak into the rack.
The bottom of the Tour Pak is metal.
Then remove the Tour Pak and drill the rack and Tour Pak holes to fit a couple of small bolts.
Then place the Tour Pak back on and secure it with the two bolts.
Then drill 2 more holes so that you have 4 bolts securing the Tour Pak.
I used allen screws and wing nuts to secure my Tour Pak.
The wing nuts were big enough that when up into the underside of the rack all I had to do was tighten the allen bolts without holding the wing nuts.
Also with the wing nuts it was easier to take the Tour Pak off when I wanted to wash the bike or just run without it.
Tour Pak
Ozark Azz
2014-2023 Touring Models
11-01-2015 12:01 AM
