99 Wide Glide rear turn signal help PLEASE
Hello All Thank you in advance for your help
Bike: 1999 Wide Glide
Issue: Was riding over the weekend and my turn signals stopped working. The front turn signals light but will not flash, the rear turn signals do not light. Upon further investigation, I discovered the wires on both sides that are up under the fender were chaffed. Fixed the wires, same problem front and back. Checked for voltage uner brake light cover. No voltage to rear turn signals. Checked fuse/breaker they are all good.
Does that mean my module got fried?
Any way to bench test it? Hate to spend $150.00 and that not be the problem.
Thank you again for helping!
Mike
Mike
There is a 6 pin connector going in to the circuit board, it comes from the main harness.
You want to make sure the power is getting back to that terminal board, if power is not getting back to that area, chances are the terminal board is not the issue.
If you have a service manual you can find it on the wiring diagram.
