What front end can I replace my 2003 wide glides front end?
Old 06-19-2019, 01:40 AM
Acethesaltbag's Avatar
Acethesaltbag
Acethesaltbag is offline
Stage II
Default What front end can I replace my 2003 wide glides front end?
I have a 2003 wide glide and I’ve grown to hate how wide the front end is. I’d much rather have a sportster/street bob style front end. Any easy bolt overs?
Old 06-19-2019, 02:12 AM
Greezey Rider's Avatar
Greezey Rider
Greezey Rider is offline
Received 2,493 Likes on 1,073 Posts
Straight bolt on....Easy, as long as you have the correct wheel, fender and related hardware for it.
I replaced my Wide Glide front end a few years ago....Best thing I ever did.
Old 06-19-2019, 02:56 AM
Dudlybooth's Avatar
Dudlybooth
Dudlybooth is offline
4th Gear
Default Lots
Lots will bolt in the 39mm world but check your axel if it's 3/4 or one inch then you know what you will need to do for your wheel and spacers fxdwg you might have issue with the wheel not working
Old 06-19-2019, 06:13 AM
Tat2u's Avatar
Tat2u
Tat2u is offline
someone would likely be keen for a swap
Old 06-19-2019, 02:53 PM
Durham man's Avatar
Durham man
Durham man is offline
Received 1,428 Likes on 910 Posts
Here we go, another wide glide going to get neutered! Honda makes a nice bike with skinny little manageable forks.
The following 3 users liked this post by Durham man:
crusader1xxx (06-19-2019), toddskill (06-24-2019), Vec (06-20-2019)
Old 06-19-2019, 06:01 PM
Acethesaltbag
Stage II
Asked for advice not your opinion but thanks 😂
The following 2 users liked this post by Acethesaltbag:
Greezey Rider (06-20-2019), perki48 (06-21-2019)
Old 06-19-2019, 06:25 PM
Dyna100's Avatar
Dyna100
Dyna100 is offline
I've considered doing the same thing. I really like the WG with 49mm forks, not so much with the 39mm forks. In the end I purchased a 2015 FXDL and enjoy both of them.
Old 06-19-2019, 06:38 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
ODC.
http://www.odcsuspension.com/en/odc/forks
Ouch ouch $$. Quality though
Old 06-19-2019, 08:36 PM
cggorman's Avatar
cggorman
cggorman is offline
Received 2,291 Likes on 1,710 Posts
Options are nearly limitless...
My 99 Wide Glide has a mixture of late model 49mm Dyna parts, touring bike hub/axle, metric headlight, and other custom stuff.
Figure out what you like and make it happen.
The following 2 users liked this post by cggorman:
cvaria (06-19-2019), Greezey Rider (06-20-2019)
Old 06-20-2019, 04:38 PM
Durham man's Avatar
Durham man
alright but let me ask you, is it the wide fork look you dislike or the handlein characteristic of the front forks? I
Quick Reply: What front end can I replace my 2003 wide glides front end?
