2012 103 clutch slippage
Have you done recents mods to increase HP and TQ......?
Did you try adjusting the clutch....?
If it is properly adjusted, with no HP/TQ gains, and is starting to slip under load, that could be a sign that the clutch is wearing out...
A stiffer spring, in my opinion, would be a band-aide to hide that fact... While a stiffer spring may delay the inevitable, it will come at the cost of a harder clutch pull...
I would replace the clutch....
jt metal (07-19-2019)
always that stuff in there ? maybe trans but not primary...i would get it out and run regular 20 50 dino or harley primary fluid.... start with that first... clutch should not go at 25 k under normal conditions
Yep. Every where else it's fine. About 4k until I shift. 2, 3, 4.....no problem holding.
Btw. Not shockproof......trans fluid. Sorry!
Your bike is running out of horsepower above 4,000 rpm,thus not pulling you forward as it did before it reached 4k.
