Breather Assembly - new vs old style
I'm currently in the middle of swapping motors in my 07 fxdb. I removed the rockers so I could powdercoat the rocker covers and realized last night that the breather assemblies are different between the 2 motors. In my old motor are the thicker cast breathers, and in the newer motor (I believe a 2012 electra glide) are these thinner stamped ones. I assume that the stamped style are an upgrade and I should continue to use them in the new motor, however, I have a couple questions.
1. I'm aware the bolts are shorter for these so I will be sure to use the existing shorter bolts for it.
2. It looks like the gaskets I have don't match with the newer style breather, and on Ronnies there isn't even a part number for the gaskets for it. Do I just need to buy whole new breather assemblies?
