No check engine light but codes
Hi everyone
Can someone please help me out here.
I recently removed my air filter as I did external vent mode but drilling the hole and running wire through backplate. After that I took a bike for a ride and some codes came in after check engine lit up these were mainly due to low battery so I thought no big deal. Today I took a bike for short ride again and as of now bike runs OK no issue no check engine light is on but ai decided to check if any new codes appeared and sure they did. Below is few shots any help would be appreciated.
Clear the codes. If they come back, you shorted a wire or cut one, I am just not sure which wire you are describing in that post.
I was really careful while removing AC backplate and paid attention without any sharp objects so I don't think I messed up any wires as that would be serious and this would probably throw check engine all the time and seems like it is not the case.
I cleared the codes as recommended and took the bike for 30 min run so far so good no new codes so maybe in fact these were some old codes not properly cleared. I will report back if anything reappear.
My bike sat for a while so I am just hoping low battery voltage create this mess with codes in the first place as this was part of initial code that popped out last week (low battery power and no power connection - as I removed the fuse)
I charged battery before today but bike still sat for 4 days so maybe my 2 years old battery is just dying which would be strange but I heard this is sometimes happening to new bikes as who knows what was done to these bikes before we got them.
Below is picture from my trans vent hose clean like a whistle 🤷♂️
All the "P" codes are related to EFI - did you disconnect anything when you had your backplate off
P2100 - EFI TCA Motor Circuit Open
P1600 - EFI Module Processor internal error / watchdog error
P1511 - EFI power management mode
I'd remove that backplate again and check connectors.
All codes shown are current which indicated by "C" suffix, for "not new" codes they'd be historical with "h" suffix.
I didn't disconnect anything while removing the backplate. I found one post indicating same codes due to low battery voltage. Hope this is what happened here but want to ride it some more to see if any check engine light will pop out. Is it possible that code will pop out without engine light coming on?
