Engine sucking air sound at idle
Hello,
I have 2006 Heritage Softail Classic, Fuel Injected. I have the weird 'sucking' sound intermittently, happens every few minutes. I attached the recording of how it sounds at idle, but basically I can hear the same sound while riding. Engine seems to be a bit jerky at lower RPM as well.
Any suggestions of what is causing it and how to resolve it? I changed already fuel filter, fuel pressure regulator/housing (this was actually cracked), fuel lines, throttle position sensor. I measured ignition coil and it measured within spec, both primary and secondary windings. I put in new spark plugs as well.
Thanks,
Erik
Thanks,
Erik
I can't open your attachment but if you believe you have an intake leak look for it with a small propane torch bottle. Put a length of rubber hose on the end and just turn the gas on and slowly run it around all the intake joints while the bike idles. If the idle changes then you've found the leak. This is my preferred method over spraying flammable and caustic fluids all over the bike.
Engine has 44K miles on it. I put in new Feuling HP+ lifters, S&S TC3 fuel pump and cam plate and Feuling Reaper 525C conversion cams. However, I had this sound also last year (stock cam plate/lifters), but much less frequent. Bike has straight pipes and K&N high flow filter.
I also ran bike without PV4 connected, issue was still there.
