Clearing codes after changing oil pressure sensor swi5ch
![Icon That](https://www.hdforums.com/forum/images/smilies/icon_that.gif)
The codes are somewhat important to hazard an opinion/recommendation... Also, what year/model Harley we are talking about....
Does the check oil light function as it should...?
That helps a lot...
if you don't have an increase of valve train (lifter & rocker) noise, it is most likely not a catastrophic loss of oil pressure, and probably the oil pressure sending unit....
However, you just replaced one. Why did you just replace the original one...?
You now have two oil pressure senders telling you there is at least an intermittent low oil pressure situation.
I would first use an oil pressure gauge to confirm it's not a problem with the actual oil pressure.
After confirming oil pressure is good, I'd check the complete length of the sensor cable,including connectors for corrosion or bad pins, looking for a possible problem.
I don't know off the top of my head, but I would also check both sensors. While rare, it is possible to get a bad sensor out of the box....
Good luck and let us know what you find...
The reason I replaced the original one was because I started getting that same code and I was told to replace the sending unit. I think what you said about bent connectors might be the problem
One other question, if the cable is corroded or bad, it doesn't look like an easy fix to replace it. Has anyone ever had to replace that cable? If so, how did you do it?
We all have done "dum" things, me more than most...
![Icon Goofygrin](https://www.hdforums.com/forum/images/smilies/icon_goofygrin.gif)
Based on your reply above, you know where to start, and what to look for.
As far as corroded cables or connectors, I will always try to clean them prior to replacing them, unless they are an easy replacement, and the corrosion is severe. A wire brush, emory cloth and/or sand paper, and an electrical contact spray are your friends here. And never forget how well an ink eraser is at cleaning metal contacts... That is if they still make them..
![Icon Denk](https://www.hdforums.com/forum/images/smilies/icon_denk.gif)
If actually damaged (other than a bent pin you could try moving back in place) there is no choice but replacement. That can be a pain in the butt, but needs to be done..
