Dyna bike lift adapter kit
Old Apr 9, 2025 | 08:29 AM
eglideic's Avatar
eglideic
Default Dyna bike lift adapter kit
I just bought a 2007 Lowrider and found out my bike lift can't lift it. I know Harley used to offer a Lift Adapter Kit 98965-99, but it is no longer available anywhere that I know of. Is there an aftermarket company that makes one?
Old Apr 9, 2025 | 08:41 AM
hattitude's Avatar
hattitude
I found these on a quick search...
NOTE: I have no first hand knowledge about the company or the product
https://villatuckycustoms.com/produc...block-adapters
Old Apr 9, 2025 | 08:50 AM
eglideic's Avatar
eglideic
THANKS. I went ahead and ordered one. I'll let you know when it comes.
Old Apr 9, 2025 | 10:14 AM
snake_eyes's Avatar
snake_eyes
Nice find! And pretty smart that someone is making them again. I know guys will chime in saying 'use a 2x4' or whatever, but those adapters are simple and fast.
Old Apr 9, 2025 | 11:57 AM
fskitch's Avatar
fskitch
Not sure what type of jack you have but there is a well known mod that makes things a lot easier.
here’s the one I have as purchased and after modifying to fit the Dyna frame.
Old Apr 9, 2025 | 12:40 PM
hd4evr2008's Avatar
hd4evr2008
https://www.youtube.com/watch?v=M8lanUaFQNE
Did that to my jack for less than $5 in parts and about a half hours time, works great.
Old Apr 10, 2025 | 12:28 AM
Djtrobbb's Avatar
Djtrobbb
I use those blocks, they work great
Old Apr 10, 2025 | 05:35 PM
Davdoodles's Avatar
Davdoodles
It's literally three identical blocks of plastic that clip to the bottom of the frame rail. Two on one side and ome on the other (there is a metal flange welded ot the bottom of the frame in one spot. The three bloks plus the flange give you your four same-height lifting points.
There's really nothing to it. Plus its way overpriced and the design and construction is fairly poor (wobbly, and easy for the blocks to 'topple, as they are fairly tall/ narrow. Three blocks of wood, stuck in the right places on the top of your lift with eg double-sided tape or screws, does the same job much better and much cheaper.
If you do a search, I recal seeing several other solutions for this standard "Harbor Freight" style lifts, including using longer bolts to reposition the lifting rails on the lift to the 'outside of the lever arms. Looks pretty simple from memory.
I hope that helps.
Old Apr 11, 2025 | 06:46 AM
NORTY FLATZ's Avatar
NORTY FLATZ
I use my old college algebra book to shim the 1 side.
FINALLY found a use for algebra!!!
Old Apr 11, 2025 | 07:47 AM
98hotrodfatboy's Avatar
98hotrodfatboy
This is exactly what I did after I had already dropped my bike not once but twice. Second time the tank got dented. I have a Craftsmen and the width now measures just over 14 1/2" and clears the drop in the frame. 1/2' x 6' 12.9 bolts..
