Cyco pads noisy??
Old Apr 16, 2026 | 03:13 PM
prockey's Avatar
prockey
Default Cyco pads noisy??
I did the cam chain tensioners last fall and finally got a longer ride in today. I'm concerned that there is more noise from the cam box and wondering if Cyco pads are noisier than OEM ?
Not sure what is causing the extra noise there so looking for advice.
2001 RK Classic
Old Apr 16, 2026 | 06:51 PM
robarosa's Avatar
robarosa
No. What is the noise? Put up a video.
Old Apr 16, 2026 | 08:02 PM
prockey's Avatar
prockey
I'll try to get a video tomorrow. Thanks
Old Apr 16, 2026 | 09:40 PM
LQQK_OUT's Avatar
LQQK_OUT
I installed the Cyco Twin Cam Chain Tensioner Shoes, and did not notice any unusual noises.
Old Yesterday | 07:40 AM
memphisharley's Avatar
memphisharley
2001 RK Classic
you may need to open it back up and have a look see. i have had no issues with those pads.
Old Yesterday | 07:53 AM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Mine run quiet. I actually tried after install, to listen and hear them out of curiosity. Silent.
I suggest you do an investigation if you can actually hear the pads or other hardware in the cam area.
Old Yesterday | 08:48 AM
jake24lt's Avatar
jake24lt
2001 RK Classic
Did you align the oil pump properly when reassembled? Retaining bolts on the pinion and or cam gears tight? Was the cam drive chain flipped over from the previous direction of travel? Highly doubtful the pad composition would make any noticeable noise.
Old Yesterday | 09:40 AM
MarlinSpike
That is a good point. Did you use the tapered alignment pins for the pump install?
Old Yesterday | 02:48 PM
prockey's Avatar
prockey
My plan is to open up the cam box and see if there is anything going on there. Hopefully not!
Old Yesterday | 04:57 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Tapered alignment pins are used for Evo and Shovelhead oil pumps.
The TC and M8 oil pumps are aligned by rotating the pump while tightening the 4 mount bolts.
