I am helping a friend with an FXR Police model with 53000 miles on it that is leaking gear oil.
There is a small crack in the chamber on the left side bottom, just in front of the pulley.
Is this a common known issues?
I suspect a casting flaw weakness that opened from heavy adbuse. Maybe even as simple as a WOT gear shift since the main drive gear and bearing are right there.
You don't mention year.
Be sure that's actually were it's coming from. Obviously, one sees a visible flaw there. But it could ave came from the seal and got there coming down.
The dye pentrant would have trouble overcoming the capillary action of the oil.
Make sure it's seeping thru and running down.
A aluminum or most any casting will trap the pentrant in a cavity like that and make it difficult to get it off and clean up before the developer is sprayed.
Clean it up good and just hit it with the white developer to make sure its coming thru.
When your thread started, it looked like a visible crack at the bottom right.
JB Weld will absolutely work. Be sure to spray with fast cleaner like brake clean or contact cleaner. When it's dry, heat with a heat gun or hair dryer which will draw the oil. Clean and heat until you're confident the oil is gone. You have an excellent adherence surface already.
I would fill the entire cavity, but do it in 4 steps. Thicker you build it, longer it takes to cure. I'd give it 2 days for every 1/4 inch to be safe.
