S&S Quickee Puchrod Adjust for 505/515 cam
Old Yesterday | 10:43 PM
Skeeter4206's Avatar
Skeeter4206
Default S&S Quickee Puchrod Adjust for 505/515 cam
I have a 2002 sportster 883 that has had the 1200 conversion. It still has the 883 heads with STD pistons. There is a 505/515 cam that was installed recently. If I was to install S&S quickee pushrods in place of the original pushrods, would the adjustment be the same. Their website says 4 complete turns on adjustment. I'm assuming that's with a stock cam. Seeing that I have a 505/515 cam in the motor, does this adjustment still apply? I know there was mention that piston to valve clearance was close with that cam. I don't want to make a mistake and not adjust them properly and cause a valve to hit the piston.
Old Yesterday | 11:41 PM
OCSpringer's Avatar
OCSpringer
Pretty sure 505/515 cams are bolt-in on 2000+ Sportsters (pre-2000 needs a pinion change) and I think Hammer recommends that cam as a good cam when using stock 883 heads. You shouldn't need to do anything additional with a bolt-in cam. I think the TDC lift on those cams is well under the 0.200 that Hammer recommends you stay under to avoid clearance issues. There is no need to change pushrods and I would highly recommend against replacing the stock solid pushrods with adjustable ones. Your just adding an additional point of failure, a possibilty of incorrect adjustment, and another place for oil to leak out. Basically, a lot of potential headache for no real benefit.
Jamied
Milwaukee Eight (M8)
May 20, 2024 12:46 PM
jp0469
Apr 15, 2024 03:05 PM
Skeeter4206
Jul 31, 2022 01:44 AM
Bbccridz99
Twin Cam Motors
Dec 9, 2021 06:30 AM
GordFXE80
Shovelhead
Jun 2, 2021 04:52 PM
