Fitment: ~2008 softail fender fit a 2002 softail
Old 11-04-2014, 11:48 AM
BrianHD's Avatar
BrianHD
BrianHD is offline
2nd Gear
Default Fitment: ~2008 softail fender fit a 2002 softail
Hello all; I'm looking to upgrade the wheel/fender look on my 2002 softail standard.. From browsing the swap meets and online, it seems that I can score a good deal on some late model softail fender and wheel combos.. Question is; can a 2008 gen fender wheel combo (180-200mm width?) Fit a stock swingarm with mild modifications on a 2002 setup? Thanks!
Old 11-05-2014, 09:00 PM
spydyr's Avatar
spydyr
spydyr is offline
No way that'll fit without some serious modification. 2007 and later houses the 200mm rear tire. 2002 I think has a 160mm tire. There's mod kits out there to go to a 200mm, and they usually come with a custom fender.
Old 11-06-2014, 02:07 PM
olongapo1's Avatar
olongapo1
olongapo1 is offline
Addition to what has already been stated concerning fender fitment, later model bikes have different axle sizes than your 02. You need to source wheels with a 3/4 inch diameter axle.
Old 11-06-2014, 06:03 PM
back again's Avatar
back again
back again is online now
Received 4,935 Likes on 2,169 Posts
Change the frame horns that come with the late model fender and it will bolt up. If you stick with a 180 tire on a 4.75 wheel in 18" you can get by with out changing the wide drive belt. If you find a wheel with the later model axle go to NAPA and get a bearing matched up to the 3/4 axle. Using a smaller 16"-17" wheel you will have to have the late model caliper with slight machine work. I don't call any of this serious modification as it is mostly a bolt up. there's a couple guys on here that have squeezed a 200 tire under there with a fender that has struts built in.
I wish you guys would stop giving info out that you know nothing about.It discourages some from even trying anything and some to spend needless money on **** that won't work.Most early Twin Came came with rear tires in sizes 130 to 150.
You can bolt on a 160-16 tire on the stock rim under a stock fender if you change the nuts under the fender by drilling out the bolt holes and using a blind nut.My sig pic has a 160 under an early FatBoy fender. PM me if you want more detail BrianHD.
Old 11-06-2014, 07:02 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,457 Likes on 5,452 Posts
https://www.hdforums.com/forum/softa...arts-list.html
Old 11-26-2014, 09:23 PM
BrianHD's Avatar
BrianHD
BrianHD is offline
2nd Gear
Thanks for the suggestions, I appreciate it - and if I have any questions, I'll PM ya.. I really appreciate it!
Brian
leohd
04-05-2020 01:03 AM
bobby5
03-16-2020 10:57 PM
tech7734
02-16-2019 05:21 PM
sniper77
12-01-2008 06:03 PM
67 LS1
10-15-2006 04:28 PM
Quick Reply: Fitment: ~2008 softail fender fit a 2002 softail
